I can not configure everything ok
I can not configure everything ok. I always have 1 left over the icon of the application.
no puedo configurar todo ok. siempre me queda 1 sobre el icono de la aplicacion.
No encuentro forma que todo quede ok.
  • Samsung S8
Settings with (?) will be always marked like that as these are Samsung independent settings and I as developer can’t determine if they are turned off or turned on - I can only direct you where you can change them.
First two settings are Android system settings and I can detect them.
