Hi,
Alarms used to be sorted according to time left for execution. The active alarm was at the top of the list visible to be deactivated. Now they appear alphabetically. The problem is that the active alarm is no longer at the top of the list and hides somewhere in the long alarm list. I have to wait for it to expire and then check for missed alarms to find out what was it about. This seems like a bug to me.
TNX
Ben Manor
Hi,
On bottom bar there is option to change sorting order.
Hi,
Sorting order fix my issue. But would it be useful to pop the active alarm (the one ringing) to the top in any order?
