Can you add statistics about the maximum speed to the program?
Could you please tell me your use-case so that I could understand better why you need this?
What if you did two activities the same day?
Hello!
I agree with topic starter about asked feature.
Use-case example: I have fast sections in a distance and want to see max speed progress.
And in case of 2 activities a day, I suppose max of max should be displayed.
OK. I will add this to TODO list and check if that can be done.
Ok, thank you in advance!
