Alarm not working during a phone call
Hi, My alarm not working during a phone call. It rings after the completion of a call. I do not want to miss important alarms. Please suggest how to solve this problem.
This is how it was designed. Which Android version do you use? Android 13 will require permission “Read phone state” granted to detect incoming phone call so if you don’t grant it then it will ring instead of delaying alarm.
Such changes will be introduced in next app version.
Hi, Thank you for the update. I am using Android version 13. So, I need to wait for your next version update to get this problem solved. Hope you will fix this soon.
