Your last update, started an issue of having me select different setting for my battery.
Have been using the software for months never had an issue until last update.
How can I correct or return to prior update.
Thanks
We’ve noticed that large group of users still use app with active battery optimizations and then complaining about app not working properly while app asked to turn them off. If you still see red block with battery message then on the right there is button to fix it.
Ps. What device do you use?
It is a new Samsung Galaxy S20 5G Ultra.
Never had issues before your last update, worked fine. Tried the fix button but it affects other services on the phone, is there anyway to reverse this last update?
Please mail me at caynax@gmail.com for older app version.
