Can't silence alarm from lock screen
I’m unable to turn off caynax alarms from my lock screen. I’m not sure if this is a bug or feature request, but this is important for me when having to enter my password while the alarm is going off.
I’m more confident now that this is a bug, because a couple of times I got the normal “dismiss” screen I’d expect while the screen was locked – though by far the majority of the time the alarm just goes off and I have to log in, access the app through the notification bar, then silence the alarm. I have no idea what the common factor is.
With that in mind, I’m using the “Caynax Alarm Clock PRO” v9.7.2 app on a OnePlus 7 Pro, android version 10. I’m happy to provide other debugging info as needed.
Does it happen every time? App should show alarm view over lock screen so there shouldn’t be need to unlock device to dismiss alarm.
That was it, I think. I had to give the app permission to display over other apps. Now it seems to be working better.
Thanks!
