Sometimes I want to dismiss a snoozed alarm. I’ve been using this app for a while, and I continually select “skip next alarm” to do this. Then I realize my mistake because the alarm does not disappear. I would like to suggest “dismiss alarm” being in the drop down menu. It could appear as an option only for snoozing alarms.
It’s available when you enter that alarm definition but pop-up menu is also good idea.
