The popular Sport Tracker Endomondo ends. Can anyone provide detailed instructions for importing data from this application into an Android 10 mobile phone? I have already downloaded data from the provider. Thank you Karel.
Go to import in the menu.
Click on import Endomondo and go to download.
Import the Endomondo Zip files and it will start importing the Endomondo files untill the 31st of December 2020.
Succes,
Klaas
Labasse04 thanks for help.
Karel - you must also own at least 3.x Caynax Sports Tracker app version to do that. If you have Google Drive sync turned on it might take really lots of time. In next app version it will be a little bit improved so you can wait for app update.
