Hello,
It is impossible to export my course. Ni Facebook. Neither in GPX, or in TCX. He does not create file of export
A .jpg file is made with statistics and map.
Me too having same issue
Sorry. Not found. sorry
I will check it. I see that local storage also generates problems.
It’s very frustrating !
Do all of you who have problems use dual-sim device?
I do not use Dual - sim. I have a file créeé Export in com.caynax, sportrack. The file remains empty. I use Huawei y5 lite
With Sony experia XZ2 android- phone, exporting solved:
Export solved partially:
NO: Sport tracker don´t save export to a new adress in memory card (SD).
export did not happen.
YES: But in internal memory exporting goes okay, I tested both GPX and TCX modes.
First I create a new path to the phone’s own memory under caynax-path
with the caynax-programs own export funtion.
for example: caynax \SportsTracker \export_mynewpath -
Next I click the export button and it’s there.
Finally (if needed) I can copy or move the file to the SD-card to my special
path. In the phone I use for copy/move a file-manager program
(today I tested with File Manager +,) -
I can move the files to PC with usb-cable. in PC it’s nice to look my sports routes.
I opened the moved file with GPXsee.
(a free pc-program in www.GPXsee.org )
Have nice times with sporting and with caynax tracker information.
I will go skiing today…
