How to delete inactive alarms?
Hey, I could really use some help with all these old alarms. After a few days, my alarm list gets super cluttered with tons of inactive alarms, and I’m looking for a simple way to automatically clear them out! Any ideas on what I can do?
I got suggestion to add option to remove all inactive alarms. Otherwise you would need to go to option: “delete alarms” and manually select alarms to delete. Ps. You can use invert selection option so if there are more inactive alarms then first select active alarms and then invert selection.
