, I have a Xiaomi Redmi Note 10 with MIUI 14.0.6 and I have problems with the GPS. I use your application with GPS with API localization sources with high GPS precision. If I walk on a street between houses at least 10 meters high on both sides, time passes while the mileage stops… the GPS signal icon of the application is colored black so the GPS signal is there and is not coloured. red I can’t understand why this happens to me. However, if before going for a walk I restart my mobile phone and your application then it will also work between houses 10 meters high, always with bee sources. What could be the problem?? I look forward to hearing from you. Greetings
