Hello is it possible to modify a session like the duration of the activity or the distance done if for exemple I stop the app and forget to put it on when I restart ?
Allô ? Can I have an answer ?
Currently you can’t but in the future there is planned option to remove points from map - without manual distance or time modification.
Ok, thank you for your reply…
And how can I do, if I forget to stop my session and see 20 mn later my arrival that it’s still running and that I want to correct the time ?
It just happened
Best regards
Oliver
I know, now you can’t. That would lead users cheating - increasing their stats.
App needs to remove time and distance = remove points from map.
