The app is only displaying everyday alarms. Other categories, i.e. work, are invisible and seemingly non functional. I have tried the different sorting options with no success.
Using pro version 8.9.5
Had similar experience today. Saw only timer alarms. Had to switch to tab mode (landscape). Click click icon on the bottom right corner and chose “all alarms”. Then switched back from tab layout to normal.
Did you notice that maybe somehow app screen resolution changed? Ps. Was it on Samsung device?
I didn’t change screen resolution
device: Xiaomi redmi 3
