Sound file stops mid exercise
Hi, I lovd the app, but every day when I start my routine, after about 30 seconds or so the sound file stops playing.
I’ve tried uninstalling and reinstalling the app, but it’s exactly the same every day.
What device and Android version do you use?
I’m using a Samsung Galaxy Tab S2, with Android 7.0
Any Chance you could record video how it looks?
You could use this app:
Inside settings turn on sound and enable “Internal”. You won’t hear sounds from app but recording app will record them. You can use low quality settings = smaller output file.
There’s nothing really to record. The sound starts to play, then after 15 to 30 seconds the sound stops, whilst the exercises continue.
