Hi!
Suggestion:
Now to turn on/off TTS you have to go to Settings. Could you please add appropriate shortcut to the main screen, or under the cogwheel in the main screen?
TYA
Hi!
Suggestion:
TYA
Suggestion noted. In future there might be short beep before TTS instructions so it would be option to mute app?
Hi,
Sorry I didn’t understand your question.
So far there are only spoken TTS messages but that new option would mute app not only TTS messages (as in future there might be short sound before spoken messages) but it should also mute any other sound.
Now I get you, thanks.
