Display over other app has been activated. It just suddenly stopped working without any settings changes made.
Samsung S10+ running on Android 12 with One UI version 4.0
Have already tried uninstall and reinstall.
Hi. Can you please mail me at caynax@gmail.com?
Could you please check whether inside app “notification” settings you have turned on “Send notifications to WEAR” and uncheck it to see if it makes a difference?
I had it as ‘ticked’ and removed it. Once removed, the screen ON is back to normal. Thanks for your findings.
