The checkbox “Vibration” is deactivated but my phone always vibrates when executing a chime.
I tried everything but no success. ![]()
I’m using a Samsung S22 Ultra.
Your app was running on my old S8+ and everything worked perfectly.
Hi. Have you tried with different sound? That sound might have built-in vibration.
Yeah, you’re right. ![]()
I didn’t even know that sounds like this exist.
I like the glitter sound file but just like you said, it comes with a build in vibration.
Edit: Found it ![]()
