Hi!
Any way to make voice information louder? For example, If I play music, I can barely hear them.
Hi!
App uses the same volume as MUSIC. ALARM volume level is louder but I wouldn’t like to modify it as it would interfere with other apps usage (like alarm clocks).
Is there a way to turn off/stop sending sound from Caynax to the device/phone?
In latest version app should turn down music, make small pause and them inform about progress.
@fnqsr Inside app voice messages settings you can control what should be spoken - on/off/
Thanks!
Is the latest version the next one to 3.3.4?
No, that’s the latest. I guess you didn’t notice change?
Ps. Would you be interested in short beep before spoken messages?
